1994 CIVIC doesn't start
Old Mar 11, 2010 | 01:47 AM
abboud shishany's Avatar
Question 1994 CIVIC doesn't start
Hi guys
A friend of mine has a 1994 civic (automatic transmission), when he comes to switch on his engine after a short period of time after atrip (even short trip), the engine won't start.
But finally it starts after many attempts, what might be the cause?
Old Mar 11, 2010 | 05:09 AM
norbster86's Avatar
Can you describe in more detail how it's not starting? Is it cranking and not firing? Is it just clicking without the starter engaging?
Old Mar 11, 2010 | 08:31 AM
As mentioned, more details about the problem are needed. If the starter cranks the engine fine but the engine won't start, then listen for the fuel pump priming and check for spark and CEL codes.
Old Mar 11, 2010 | 07:34 PM
gjb149's Avatar
Default main relay
You can re-solder the main relay circuit board solder joints for basically 'free'. those things tend to be a bit problematic. The solder joints tend to crack (use a magnifying glass to inspect them).
Old Mar 11, 2010 | 07:36 PM
^The main relay is a likely culprit but it's a better idea to troubleshoot to first identify it as the problem.
Old Mar 12, 2010 | 09:16 AM
Thank you my friends for your response.
The starter cranks the engine and the spark plugs are new but the engine does not run.
The fuel pump priming is heard when you turn the key on and the check engine light goes off, every thing seems good.
Old Mar 12, 2010 | 09:51 AM
You need to check for bright white spark at the spark plugs. Click Spark link in my signature.
Also inspect the distributor cap and rotor. How old are the plug wires?
civic_owner
Aug 1, 2012 07:19 PM
sammylou
Sep 14, 2011 12:24 AM
Civic116
Aug 14, 2010 01:50 PM
00civic_si00
Jul 27, 2007 08:47 AM
ParaAlpha
Dec 23, 2005 10:23 PM
