1994 Honda Civic 1.6L (D16Z6) died while at a stop light..
I was on the interstate about to make a turn off into a side road, I was stopped when it happened...it just completely died. Wouldn't start or anything. The battery and starter were fine as I could hear the engine wanting to start, but it wouldn't completely turn over and start up...
I gave it a complete tune-up recently (plugs, wires, fuel/air filter, cap & rotor. I checked to make sure all these were fine, didn't see any problems..) Now I have not even the slightest clue as to what it could be. All my belts (alternator, power steering, etc.) appear to be fine. What the world could it be? I had it towed to a shop and will be awaiting a phone call tomorrow but I'm just wondering what are the possibilities... Everything electrical appeared fine when I went to try and start it again and again. CE light appears and goes off after a second or two, nothing out of the ordinary. If it's a timing belt, is there a chance I bent valves seeing as I tried a couple of times to start it to see if anything would straighten out (which it didn't..) |
It could be the fuel pump.
when you turn your key to the on(II) position can you hear the fuel pump priming? |
Originally Posted by littlemanx23
(Post 624789)
take the oil cap off and shine a flashlight towards the cam and see if the cam turns when you have a friend crank the engine. |
my guess would be fuel pump as well. Does it choke and sputter when you crank it?
Check to see that your fuel filter isn't plugged. |
OP any update?
I have the car back now. It happened to be something in the distributor/ignition coil. Replaced the distributor assembly and everything is back to normal again.
