1998 Civic HX Tranny Slip
Old Jan 4, 2012 | 06:33 PM
Civic4952's Avatar
Default 1998 Civic HX Tranny Slip
Currently having tranny problems in my 1998 Civic HX with a CVT automatic transmission seems to be slipping sometimes at a go and sometimes when I hit the gas pedal quickly...I'm also having surging idle problems along with it. Could the surging idle be related or could it be from my tranny fluid being old and worn out? (It has been give or take 40k miles since tranny flush) Any help/Advice is much appreciated.
Old Jan 5, 2012 | 06:40 AM
ChristianL's Avatar
They made automatic HX models?
Anyway, I would check the trans for leaks. I think the CVT runs off of vacuum pressure, but can't remember at the moment. Is there anything in the owner's manual about changing the belts in there? I haven't seen the inside of a CVT since I was repairing an old Honda Odyssey ATV several years ago.
Old Jan 5, 2012 | 10:45 AM
briceman124's Avatar
If it were me i'd check the tranny fluid and pray to god it isn't black with metal shavings.
Old Jan 5, 2012 | 04:56 PM
Civic4952's Avatar
The Tranny fluid is kinda a reddish which im told is the color it comes....If the tranny is in fact ran on vacuum pressure then that's probably my problem because sometimes when i come to a quick stop ill hear a sort of ghost sound or air escaping from my engine bay which could possibly be an air leak...?
Old Jan 5, 2012 | 04:57 PM
Civic4952's Avatar
Also this problem seems to be alot worse when the motor is cold.
swh95
Sep 1, 2009 08:29 AM
Methu969
Feb 19, 2007 06:43 PM
my ocean gia
Nov 24, 2005 10:45 AM
