1998 LX motor mount replacement
So I've been digging through searches for about a week, but most motor mount threads are aimed at swapping. My LX has a mean vibration in reverse and also if I slow down in gear or feather the gas pedal a bit. Would you guys suggest a replacement of all 5 mounts or do my symptoms point to a specific mount?
Either way I'll need to buy something, does anyone have a good suggestion for a reasonable price brand/parts seller?
If a motor mount is bad, you usually be able to see crack or break on rubber section. Perform visual inspection and determine which one needs replacement. Front mount's more suspect for wear/break than the rest.
alibarbar37
Feb 20, 2014 06:45 AM
1998civiclx
Jan 1, 2008 12:45 PM
