1999 civic ex engine turning off
Old Feb 15, 2005 | 11:30 AM
roco's Avatar
Default 1999 civic ex engine turning off
Hi, I was wondering if there is anyone can give me some advice. this happen only when it rain. already happen twice. ok I was driving back home last night and the road was wet cause of the rain but there was a section really flooded and after a passed 10 seconds later the engine turn off, the RPM was going down and down to 0 and all the light came on like brake, battery, etc. so I was trying to turn it back on, but the engine sound like there was no GAS, but there was. anyway I think something got wet like any electrical sensor but I dont know .
I NEED SOME ADVICE
Civic LOVERS
Thank you.
Old Feb 15, 2005 | 12:30 PM
grncivicvtec's Avatar
Default RE: 1999 civic ex engine turning off
What kinda of itake system do you have.
Old Feb 15, 2005 | 01:12 PM
roco's Avatar
I Dont have an Air Intake system, I think something got wet. but I'm not sure what will cause the engine to turn off when is raining, But when there is no Rain there is no Problem.
Thanks
Old Feb 15, 2005 | 02:14 PM
Remmy's Avatar
I think I know whats wrong. There was water in your distributor. They cut off when water gets in. Once it drains it will let you start your engine back up. You might need to get it replaced. Hitting a puddle also is a no no, water seriously splashes up into your engine. Ive found mud stuck to the bottom of my hood before wwhich tells you that can happen.
Old Feb 15, 2005 | 02:16 PM
Kappa22's Avatar
Yeah, water in the dizzy. That's why you cover it when you clean your engine... Although it is a little high up, so that would have to be some serious puddleage. Water in the alternator can also cause problems, but not the kind it sounds like you're describing.
Old Feb 15, 2005 | 02:32 PM
roco's Avatar
OK, so it sound like I need to change the Distributor. after ten minutes of trying to star the engine it will star like nothing happen..........
Ok I will try that
Thank You.
Old Feb 15, 2005 | 07:37 PM
Kappa22's Avatar
You might just want to take the cap off and check the contacts first...
Old Feb 15, 2005 | 09:33 PM
sacicons's Avatar
get a blow dryer after it. if that doesnt help, replace it. thats how my first one went out. i was driving in the rain, then when i got where i was going, it wouldnt start anymore. so i dried it out till it would, and the problem just got worse over the next few days, till i had to replace it.
Old Feb 16, 2005 | 06:27 PM
roco's Avatar
Hi
I was looking online the distributor, and it has so many different parts like Distributor cap, rotor, housing, etc I'm not sure which one to replace
can you advice.
Thank you
Old Feb 16, 2005 | 07:34 PM
sacicons's Avatar
the thing you want is the distributor. it should come with the coil, ICM, and all the internal parts. there is a good chance that its just the ICM, but the rest will probably follow it in breaking. and the ICM is like 20 bucks cheaper than the whole thing. and its not worth buying just the ICM unless you are sure thats the problem.
