2 questions
an underdrive pulley is slightly bigger than stock so that it spins the accessories slower. basically, it takes a certain amount of hp to spin the accessory once. so if it spins leess rpms, then it ends up using less power than normal. also, they are usually a little lighter. as a warning, ive heard of the crank pulleys tearing up the motor, as it doesnt remove vibrations like a stock one does. expect a couple of horses from these. not groundbreaking, but every little bit helps.
the vibrations are from the harmonic vibrations of the reciprocating mass of the engine moving up and down. a stock crank pulley has rubber in it that is designed to dampen the vibrations. ive heard from people who had the unorthodox racing pulleys and had that problem, so its not all about the quality of the underdrive crank pulley.
ORIGINAL: ohbiskits
yea they dont have harmonic balancers...or they are not harmonicly balanced...its one or the other but thats the reason they dont stop and cause vibrations
ORIGINAL: sacicons
unorthodox racing is one of the best ones on the market. and i t still has problems. its a design flaw, not a manufacturing one.
I've already written this in 2 other posts.. crappy testing is one of the factors! Proper testing will help produce better products that will work as intended. Obviously, since the auto manufacturer could produce a pully that worked.. it is possible to do it. It just requires testing... and obviously fixing the problems that are found from testing.
