2000 ex valve chatter???
Old Jan 4, 2011 | 06:35 PM
hghlndr85's Avatar
Default 2000 ex valve chatter???
i bought a 2000 ex coupe 1 owner only 60k miles, well maintained. i bought it home, changed oil over to synthetic and drove it. noticed the motor seemd a bit more noisy with the synthetic in it vs the conventional. put like 250 miles on it and noticed when i start it cold i get valve tapping and chatter, not horrible but noticeable. i switched back to conventional oil and it still does it, could it be just a fluke? does it need valve adjustment? seems to go away mostly after its warmed up. i just dnt wanna cause more damage. im in pa and its like 25-35 degrees here now
Old Jan 4, 2011 | 06:39 PM
Valves are often noisy when cold. It shouldn't hurt anything.
You should check the adjustment though, the spec is to adjust every 30,000 miles.
Old Jan 4, 2011 | 06:41 PM
add some lucas oil, that should stop it, you can also stop at a shop and see if your valves need adj, should only take 30 mins
Old Jan 4, 2011 | 07:19 PM
Sounds like all the oil in the head may be draining to the oil pan. You might want to install a different or new oil filter.
Old Jan 5, 2011 | 03:58 AM
hghlndr85's Avatar
i installed a new filter when i swapped oils. im using a purlator pure one filter that has drain back prtoection,what filter do u reccomend? also im using honda 5w30 oil
Old Jan 5, 2011 | 02:18 PM
TheJGB3's Avatar
My 2000 Civic EX has noisy valves when cold. It has done this since I have owned it (76,000mi) now has 127,000mi. Currently runing Mobil 1 0W30 and Honda oil filter (15400-PLM-A02). Timing belt/wp, and valve adj done @ 94,000mi. (made no difference to the noisy valves when cold).
Slammed98silvercoupe
Oct 29, 2010 04:20 PM
Peg_Leg
Jun 4, 2010 11:31 AM
fun_friend1969
Feb 8, 2009 10:41 AM
nivek
Oct 19, 2006 12:01 AM
antimarlin
Sep 14, 2006 05:12 PM
