2003 Hybrid overheating. Cannot find reason.
Old Sep 21, 2010 | 05:43 PM
jasonkoller's Avatar
Default 2003 Hybrid overheating. Cannot find reason.
On Sep-16 my hybrid started making grinding noises and went to half power.
The temperature was high and the OBDII reader gave me P0335 [Crankshaft Position (CKP) sensor circuit, no signal]
I bought a new TDC Sense and replaced it today as well as topping off my fluids.
The coolant had gotten low.
After a few miles of test driving,
The check engine light came on and the car had the same symptoms.
This time the OBDII reader came up with
P1449 [Battery Module Overheating,Battery Cell Overheating, Battery Module Individual Voltage Input Deviation, Battery Module Deterioration, Battery Module Deviation]
P1600 [TCM Internal Watchdog Operation]
I doubt the battery would cause the noise.
I'm leaning more towards to Transmission Control Module.
What is the TCM and where is it located?
Old Sep 22, 2010 | 01:11 PM
Default Update
Alright,
I've isolated it to the the radiator fan.
It seems that causes the overheating which causes all the other stuff.
I tested all relays and fuses.
They all work.
I tested the fan motor.
It works.
I tested the voltage to the fan.
it reads 0.
Old Sep 22, 2010 | 03:23 PM
Default Update 2
I got the fans working,
And double checked all my fluids,
But it still overheats.
It didn't throw any OBDII codes this time,
But I suspect that's because I got home before it did.
Any ideas?
Old Sep 22, 2010 | 06:37 PM
norbster86's Avatar
Make sure to bleed the cooling system of air pockets. Sometimes there's a bleeder close to the thermostat (check the manual for your car).
Also, a thermostat that's stuck closed would cause overheating without throwing trouble codes.
rekomstop209
12
Dec 5, 2012 12:58 PM
TooFastForYa
Nov 9, 2007 05:17 AM
99silverfox
Sep 16, 2007 10:10 PM
Civic Unrest
Jun 23, 2006 02:33 PM
Ray012874
Nov 4, 2005 08:08 AM
