2008 HCH 12v problem
Took it to the dealership and they said I needed to replace the IMA battery, which I did, IMA indicator was on, now off. Now the 12v battery won't charge. I have a clamp meter and have 3 amps on ground, the red (+) wire between the fuse box and the battery, the little wire from red to wherever and 0 amps between red and the engine.
I'm at a loss on this problem. Is there a fuse between the generator and the battery? New 12v battery as of yesterday. I can throw the charger on it and the car works temporarily. |
12v cont
Why is there no information about the 12 volt battery? I'm sure there is, I just can't ever find any.
I guess there shouldn't be amperage between the starter and battery (after a closer look).
Does the HCH require a special battery that's not available from O'Reilly? |
| All times are GMT -8. The time now is 07:33 AM. |
