5th Gen Wheel Hub Bearings HELP!!!!
Old Jun 1, 2008 | 08:33 PM
Grimey Civic's Avatar
Default 5th Gen Wheel Hub Bearings HELP!!!!
anyone know where i can get a good set ofwheel hub bearings for my 94 civic dx.thinkingaboutconverting to 5 lug now. figure it'll be easier to find rims.
Old Jun 2, 2008 | 09:09 PM
TheJGB3's Avatar
Default RE: 5th Gen Wheel Hub Bearings HELP!!!!
Doing a 5lug conversion is more involved then you think.
You will have to buy
Frt & rear spindles/knuckles from the donor car (whichusually include the hub and bearings)
Frt & rear brakes from the donor car (calipers, pads, rotors, etc)
and time/expertise to do the swap. If you don't exactly know what you are doing, I would recommend you DO NOT attempt it.
There are a lot of 4 lug wheel options for you.
Your Civic has a 4on100MM bolt pattern
Most 4 lug aftermarket wheels are "dual drilled" (meaning they have a 4on100mm AND a 4on114.3MM bolt pattern) so the wheel will have 8 holes in it and fit cars with either bolt pattern.
acexxxoasis
Jul 8, 2008 09:10 AM
Niko
Sep 30, 2007 10:24 PM
Niko
Sep 24, 2007 09:32 PM
fglaustin
Apr 16, 2006 02:03 PM
naucrx
Dec 6, 2005 11:05 PM
