6th gen window off track
Old Jan 17, 2009 | 09:08 PM
supersize's Avatar
Sir Banned-a-lot
Default 6th gen window off track
so i seen there was a recall or something about the driver side window falling off track all the time on the 97 civics, am i still avalible for that? cause my window is off track and i have no idea how to fix it, but what im worried about is if i pay someone to fix it, will it happen again? what would i need or what should i do?
Old Jan 17, 2009 | 09:24 PM
jprommel's Avatar
Angry Admin
Ok
It is a rather quick fix once you get good at it
15 min tops
To remove door panels there are five screws I believe u need to take out and then three to take speaker off.
There is one behind inside door handle, one in the little holder thing and the others are behind speaker.
Once you unscrew these take off the trim pieces. To take off the one in armrest put a flat head screwdriver underneath and pry up.
For the speaker screwdriver and pop it off you will see the screws
Then for the panel to take it off just put screwdriver in-between panel and door and pop around the edge not the top edge but the bottom and side
Then there is a 10 mm bolt that u should remove to place window back on track. Once done lube everything up nicely and put everything back.
Putting the door panel on is sometimes difficult.
I do not know how to really describe it but put one corner of the top part in and then work your way back.
The problem is with a faulty window regulator I do not know if you are still eligible, I never go to the stealership.
Old Jan 17, 2009 | 09:55 PM
Nice job Josh. Also spray some Silicone lubricant into the rubber side channels where the window edges slide.
Old Jan 18, 2009 | 01:49 AM
jprommel's Avatar
Angry Admin
wow lotsa spelling mistakes =[ i will fix that in the morning
Old Jan 18, 2009 | 12:17 PM
jprommel's Avatar
Angry Admin
Spelling fixed
Old Jan 19, 2009 | 09:15 PM
supersize's Avatar
Sir Banned-a-lot
picture diagram anywhere? i have no idea where to spray lube or anything, im illiterate.. what part would i need to fix so it dosent happen again and again??
*EDIT* what would i all need to do to make it a power window?
Old Jan 19, 2009 | 09:32 PM
Justin13's Avatar
Banned
Honda windows come off track SO GOD DAMN MUCH. mine came off track like 2 months ago and i fixed it but then it came off track again and made it go up and said f*ck it im leaving it.
Old Jan 19, 2009 | 09:52 PM
jprommel's Avatar
Angry Admin
ohh u have manual... same story but kinda different. i hate to say it but i believe its just a tsb(technical service bulletin) so you arent gonna get it done for free. but ya i will do a full write up eventually. but you can get away w/out lube for awhile.
Old Aug 7, 2009 | 05:25 PM
bmelloh's Avatar
Is there supose to be a bolt in the bottom of the hanger track? or does it just float? I need to know cause Im having the same problem, seen the hole in the bottom of the track and thought the bolt fell out.
Old Aug 7, 2009 | 06:02 PM
jprommel's Avatar
Angry Admin
can yo uget a pic i'm not one hundred percent what you mean. There is only one bolt as far as i can recall but i luckily havent had to put it back on in awhile.
acexxxoasis
Jul 8, 2008 09:10 AM
Slickone
Jun 20, 2007 08:45 AM
Kenneth Ames
Feb 25, 2007 08:04 PM
Kedawei
Feb 12, 2006 04:29 AM
naucrx
Dec 6, 2005 11:05 PM
