90 civic hatch b18a1 swap help
Old Sep 6, 2011 | 02:07 PM
pilcher311's Avatar
Default 90 civic hatch b18a1 swap help
i have a 90 civic hatch with a b18a1 and it seems like its not running to its full potential. its really hesitant off the bottom and it dosent seem to rev out i looked at the vacuum lines and there is a purge cut off and pressure reg. cut off solenoid valve one is there and one isnt idk if this is out off the car the motor came from is just what the hatch has stock someone help i want this damn thing to run right..thanks
Old Sep 6, 2011 | 04:18 PM
rburch77's Avatar
A pic would help! So we can see how you have it ran currently!
Old Sep 7, 2011 | 09:32 AM
pilcher311's Avatar
i hope this helps because its really starting to get annoying
Old Sep 7, 2011 | 10:11 AM
Check your timing first of all. Retarded timing could cause sluggish starts I would think.
You say it is not "revving out"? What exactly are the symptoms? Does it seem to hit a rev limiter? What ECU are you running? I would like to assume that this is not a fuel pump issue as it should be able to keep up with a stock B18 IMO.
Old Sep 7, 2011 | 12:20 PM
pilcher311's Avatar
Timing is good and it runs ok when u first start is the is will start stuttering off the bottom and when u drive it it's just won't rev out it will fall on it's face the gas tank keeps getting vacuum locked and it will free rev fine but once u drive it that's when it's starts to **** up that's why I thinks it's vacuum or fuel
Old Sep 15, 2011 | 01:56 PM
rburch77's Avatar
If i remember correctly EF's dont have the pressure reg. cut off solenoid. I just had the one on mine and it ran great!
If you posted a pic i dont see it! Im thinking you might have the vacuum lines crossed.
Old Sep 23, 2011 | 12:48 PM
pilcher311's Avatar
it has the b18 in it so it should have both vacuum solenoids?
Old Sep 26, 2011 | 01:11 PM
rburch77's Avatar
No! On mine, my fuel press reg ran off intake manifold.
01honcivic
Feb 21, 2015 07:29 AM
Chandrella Abbott
Dec 19, 2011 03:40 AM
ef9101
Feb 14, 2010 08:26 AM
alteredimages
ED-EF Swaps
Mar 18, 2007 07:03 PM
92B18A1Hatch
Sep 17, 2006 07:56 PM
