91 dx hatch blowing smoke at full throttle?
okay, i just test drove this 91 civic hatch with the d15b? anyhow, it just got out of the shop getting a new head gasket. the guy only wants 1000 for it, so i figure ill be putting some work into it..
engine has a sluggish start, but seems to run pretty strong.. its an automatic :-(
but question is this, when i floored it the car is blowin a bit of white smoke.. i need to pull the plugs and take a look at them, but would anyone have an idea as to what the culprit for this could be?
it doesnt smoke unless completely floored and the od kickin in.. but then smoke goes pourin out..
any help would be greatly appreciated or some ideas as to what to look for to self diagnose the problem from this point.
Since you have white smoke, that can either mean you are running lean or burning coolant. Since it only happens when you floor it, you are probably running lean. When you floor it, two things must happen. The PCM (engine's computer) has to richen the fuel mixture by increasing the injector pulse width (how long the injector sprays fuel). The PCM also has to advance the ignition timing. The first thing i would do is replace the plugs and wires. Its not that expensive and you just bought the car so why not. I would also have the injectors cleaned since it is an old car and they might be dirty. You can clean them by using SeaFoam (check in the DIY section). Also, you can have them professionally cleaned but make sure an injector cleaning machine that uses pressurized solvent is used b/c some places just put a bottle of injector cleaner in your gas tank.
silverbullet01
Jul 2, 2010 03:11 AM
Denis Gregoire
May 29, 2008 06:02 PM
4doorcivic9
Apr 8, 2007 12:06 AM
