91' hatch- A/C blows fuse
My a/c had been running great & then it just started popping the fuse instantly! I've checked resistance on the compressor & clutch. I've checked resistance from comp. back to the relay. Checked from relay back to the fuse box(under the hood). Everything reads out OK. What next? Something as simple as the a/c button on the dash? It's hot in Florida & would love to have my a/c back.
I do have power up to the compressor. The fuse does not blow when unplugged w/car running & a/c on. Using an Ohm meter, if the compressor reads out OK...can the compressor still be shorting out? Car electrical is not my calling.
Compressor is shorted then. Probably the clutch coil itself is shorted, but check for frayed wires on the top of the compressor.
Coil can be replaced without changing the whole compressor or needing to recharge the refrigerant.
TexusMain
Jun 14, 2012 04:40 PM
ls40095
Nov 18, 2010 09:21 AM
civic2001
Sep 16, 2010 09:03 AM
ktm518
Apr 18, 2010 10:18 PM
