93 cx rough idle & loss of power
Old Sep 7, 2011 | 10:17 PM
will100's Avatar
Default 93 cx rough idle & loss of power
i have a new fuel filter as of a few months ago, i oput the right gas in and stay up to date on oil changes. it had almost 150,xxx miles and idle was fine this morning. i drive up a canyon to get to work and half way up i noticed a definite loss of power. when i came in to the parking lot it was idleing rough and puttering. i dont notice anything on the highway but starting from a stop i can feel a big difference. im really hoping i didnt rev to high on the way up. first time i found myself not loving the 1.5 and tall gears. could i have done some internal damage? how bad could this be?
Old Sep 8, 2011 | 05:00 AM
Idle the engine and disconnect the fuel injectors one at a time to see if you have a dead cylinder. Another common reason for sudden loss of performance is having the timing belt skip a tooth. To check that take the upper plastic cover off and turn the engine by hand to TDC, check if the marks line up.
Old Sep 8, 2011 | 12:22 PM
will100's Avatar
it seemed more erratic then one cylinder dead this morning i went out. i started with the spark plug wires and one was loose, not of so it was sporadic firing. man i am glad it was something small. thanks for your help.
Old Sep 12, 2011 | 01:27 AM
will100's Avatar
well it was to good to be true. the next day as i tried to climb the mt on my way to work i found i am still missing alot of power. and my exhaust has a heavy pop to it. the idle is still rough just not as bad as the first night. i could see it be a timing issue. but what would make that exhaust sound? i had an MG for a while that did that and i knew one of the lobes on the cam had been worn down enough that it was not opening the valve. thats the only other experience i have had with that noise
Tsb2012
Apr 11, 2013 05:13 PM
Kwright
Dec 7, 2011 01:55 PM
actionAction
Sep 27, 2010 07:30 PM
Bgsxr007
Jun 7, 2008 07:52 AM
brinriha
Jun 14, 2007 10:55 PM
