93 dx coupe trans. leak
Old Jun 16, 2010 | 11:23 AM
RedSno's Avatar
also when i went to that page and i put in my car the dimensions of the seal are different from the page you gave me is that a problem lol?
Sorry for the double post my bad.
Why would you do that? Transmission fluid is only leaking from where the axle inserts into the transmission, right?
Old Jun 16, 2010 | 11:25 AM
Enter you VIN and then navigate to the Transmission Housing section. Part 10 is what you need.
RedSno's Avatar
Yes that and that plate thing
Old Jun 16, 2010 | 11:26 AM
Those two leaks may be one and the same. Replace the axle seal and go from there.
Old Jun 16, 2010 | 11:29 AM
RedSno's Avatar
i think its coming out of the drivers side joint i could be wrong
Old Jun 16, 2010 | 11:30 AM
Do I see the driver or passenger side axle CV joint in you picture?
Old Jun 16, 2010 | 11:32 AM
Do I see the driver or passenger side axle CV joint in you picture? If it's the driver side, then buy part 12 in the Majestic illustration that you posted (post #8).
Old Jun 16, 2010 | 11:35 AM
RedSno's Avatar
its drivers side i belive when looking at my car straight on its on the right side of the trans.
Old Jun 16, 2010 | 11:51 AM
Always refer to the side of the car from the car's perspective, or if you were standing behind the car facing forward. Anything on the drivers side of a US model is a LEFT side part.
The two axle seals can be replaced with the transmission still in the car. To replace the other seals, you would need to remove the transmission and take it apart.
If an axle isn't pushed all the way in, it will leak. But since you found the transmission empty before removing it to change the clutch, that probably isn't it.
Majestic is great but ordering a single small part from them isn't worth it. They charge $5.00 per order "handling" which will eat up the discount before you even get to shipping. Most parts stores or of course your local Honda dealer can supply these seals.
