94 Civic dx died
Old Jul 14, 2009 | 01:46 PM
SlammedRT's Avatar
Default 94 Civic dx died
just picked up a 94 civic dx 5 spd. i was going down the road in 3rd doing about 35-40, and it just died, i checked the plugs and there fine and getting spark and i could hear the injectors clicking, any help would be greatly appreciated as i need my car to get to school in the morning
Thanks
Rudy
Old Jul 14, 2009 | 01:59 PM
Do you hear the low humming sound of the fuel pump priming for 2 seconds when the key is turned to ON(II)? If so, check whether the timing belt snapped or slipped out of time.
Old Jul 14, 2009 | 03:43 PM
SlammedRT's Avatar
fuel pump turns on, ill check the belt, how would i know if it jumpd timing
Old Jul 14, 2009 | 04:33 PM
Pull off the valve cover and upper timing belt cover. With the front end on stands, turn the crank bolt only counterclockwise with a breaker bar until the cam pulley is positioned at TDC1. At this moment, check whether the crank pulley is also at TDC1:
Old Jul 15, 2009 | 06:45 AM
SlammedRT's Avatar
well i deffiantly think it jumped timing
Old Jul 15, 2009 | 06:52 AM
Remove the dreaded crank pulley, install a new timing belt, correctly set the mechanical timing, and then compression test the cylinders to check for possible engine damage. Good luck.
02CivicLX
12
Sep 18, 2007 04:34 AM
ZackG
16
Aug 29, 2007 06:08 PM
jonsrich
Nov 20, 2006 08:19 AM
civicfan87
Jan 3, 2006 01:00 AM
AndyI
Oct 6, 2004 09:36 AM
