94 Civic Electrical problem
Old Oct 6, 2011 | 06:04 PM
robby100's Avatar
Default 94 Civic Electrical problem
My friend has an electrical problem I'm trying to help diagnose on her
94 Civic LX. After having some transmission work done, the mechanic
told her there is an electrical problem where she has to connect a
wire between the two terminals on the right edge of the under-hood
fuse box in order to get it to start.
So basically, when she turns the key to the on position it appears
completely dead. She connects the wire between the two terminals
and the dash lights come on, the car can be started. At which point you
can disconnect the wire and everything is fine until you shut off
the car, at which point you have to go through all this again
to get it started again.
Any ideas on what is going on?
Thanks in advance!
Old Oct 6, 2011 | 06:18 PM
Main fuse blown (often due to mechanic neglecting to disconnect the battery before taking car apart). That's the case if the two terminals are the ones with a big white wire on each. Or are the two terminals where a fuse should be? The big fuses in the underhood box are secured with screws.
Old Oct 7, 2011 | 03:35 AM
robby100's Avatar
Its actually two black wires that are connected to those terminals with
screws. If its the main fuse, would the car continue to run when she disconnects the little bypass wire she is connecting?
Old Oct 7, 2011 | 04:27 AM
Yes it would. Have you checked the fuses in the box?
Old Aug 5, 2015 | 05:41 PM
Swamp's Avatar
I'm having a similar problem with my 94 LX. I can get it jump started, but it will not start on its own. Replacing the 80A "battery" fuse in the under-hood fuse box didn't do the trick. Any other suggestions?
civic_newbee
Dec 11, 2007 09:13 AM
spinjunkiee
Jul 16, 2007 05:26 AM
wjelmer
Nov 3, 2006 10:19 AM
Kuttooz
May 5, 2006 03:18 PM
rick90yj
Aug 14, 2005 08:08 AM
