94 civic losing power plzzzzzz help????
Old Jun 16, 2004 | 09:28 PM
hennebury's Avatar
Default 94 civic losing power plzzzzzz help????
hi I have a 94 civic i just bought. when i got it it was sputting when you give it gas at the take off and sometimes died at idle i took it to the garage they put a new temp sensor in and fixed it as it was running rich but it still has a miss i have repalced the plugs and air filter and put a profurmance muffler on it you can hear it pop kind of like a backfire almost when you give it gas
does anyone know if this could be cause be a clogged catalytic converter ?
also when you turn off the car you can hear the exhast ticking under the car up towards the front of it
its not a back fire but more like a putter when you give it gas if you let up on the gas its fine or after the rpms pick ups its fine
also i only get like 275 km on a full tank of gas
Old Jun 17, 2004 | 03:29 PM
NTX's Avatar
NTX
Default RE: 94 civic losing power plzzzzzz help????
The ticking exhaust is fairly common and clogged cat wouldn't cause a backfire. I would look at the ignition system and be sure your timing is correct.
Old Jun 17, 2004 | 05:22 PM
hondaholic9's Avatar
"you can hear it pop kind of like a backfire almost when you give it gas"
My civic does this on the change up from 1st to 2nd and it doesnt seem to matter how fast/slowly and at what revs U change. At the mo Im getting round it by slipping the clutch on every change up. [:'(]
At first I put it down to my powerflow exhaust, but the problem has only become really apparent in last 6 months, around 4 months after exhaust was fitted. NE IDas guys? Could it B the same prob as 'hennebury' is having?
Ad
Old Jun 22, 2004 | 10:08 AM
hennebury's Avatar
i was told it was to do with the air intake what could it be does anyone know ?????????
powellsam
Feb 20, 2012 06:51 AM
LionSpratt
Aug 21, 2011 11:59 AM
hghlndr85
Dec 19, 2010 05:39 PM
badar_VTi
May 6, 2010 12:48 PM
krazlegs
Jan 27, 2007 10:45 PM
