94 Si alternator barely charging.
Old Aug 17, 2011 | 01:27 PM
Mcgarvie's Avatar
Default 94 Si alternator barely charging.
i have a 94 ej1, d15b7/d16z6 mini me, and my alternator is charging 12.55 volts, it will run with a battery cable off. checked the black/yellow stripe wire on the plug an got a good reading. 12.55 at the alt post as well. its a new alternator as the last one was doing it to.
Old Aug 18, 2011 | 08:08 PM
conceptualpolymer's Avatar
The battery voltage should be up around 14V when the engine is running. If not and you are certain the alternator is okay, have your battery checked.
Old Aug 29, 2011 | 12:50 PM
JFizzle9191's Avatar
you could have a drain somewhere.. i also had a new alternator and battery and something kept draining the battery.. ended up being a short in a wire
Mcgarvie
Aug 17, 2011 01:26 PM
b-rice99
Nov 13, 2010 04:21 PM
Nitecaller
Sep 19, 2010 09:39 AM
burndog
13
Feb 27, 2010 01:11 PM
danomatic93
Oct 11, 2009 07:19 AM
