95 Civic dash light will not go away
Old Sep 16, 2011 | 11:24 PM
Lambo Civic's Avatar
Post 95 Civic dash light will not go away
My ABS light is always on. I just changed the front disc brakes and pads (calipers are two years old and had my friend from Mercedes-Benz inspect them), and changed my disc brakes and pads in the rear 6 months ago, calipers also okay. I use AutoZone's Duralast discs and pads, but I do always get the anti-lock brake discs. Never got the non anti-lock ones anyway.
What could this problem possibly be?
Thanks.
Old Sep 17, 2011 | 04:05 AM
It won't have anything to do with the calipers or pads. The ABS computer self-checks the wheel sensors and the hydraulic module.
Check the wheel speed sensors and wiring for damage or being unplugged. Check that the CV axles are the ABS type-- they have teeth on the outside of the joint to actuate the sensor.
It should work that if you put a test jumper in the same place as for the ECU, the ABS light will blink out the trouble code. Would have to search for further info on that procedure.
MasterJT
May 15, 2010 05:45 PM
yairsaenz83
Feb 22, 2007 07:41 PM
sir_nasty
Mar 27, 2006 03:09 PM
derekdunham
Nov 20, 2005 10:30 AM
derekdunham
Jul 25, 2005 10:39 AM
