95 Civic needs new 9003 harness, help?
Old Apr 19, 2008 | 10:58 AM
gen3honda's Avatar
Default 95 Civic needs new 9003 harness, help?
Hello, I just bought a 95 Civic with missing headlight assemblies. One of which they decided to cut the harness which you plug the 9003 highlight bulb into. I have found this harness online for cheap, but my question is... which wire goes where? There are 3 wires, if I were looking at the harness with the middle connector onbottom ( | _ |), which wire would go where?Thedriver's side of the car is the side I need to do this on, if that matters. Thanks in advance for your help!
EDIT: Also, am I going to need that ring that looks like it locks the bulb into the headlight assembly? Or does the bulb itself lock in? Will new assemblies come with this?
Old Apr 19, 2008 | 02:37 PM
jim9418's Avatar
Default RE: 95 Civic needs new 9003 harness, help?
If you go to a junk yard and get the stuff you need, the wires color coding will match what you have. Should be a no brainer. Look at somebulbs, you'll see the roundbase is part of the bulb. Be sure you get the protective rubber cover to keep water out of your light assembly.
Old Apr 19, 2008 | 03:12 PM
Yeah just go to a junk yard and cut a plug out of a parts car, then splice the wires by color.
There's a wire clip that holds the bulb in. I think if you buy the complete assembly from a dealer you get a bulb, clip, and rubber boot already installed in it.
Probably the colors are the same on the other side of the car you could check there.
Old Apr 19, 2008 | 06:28 PM
gen3honda's Avatar
Will headlight assemblies from a 95 4 door Civic fita 2 door?
addiction2bass
15
Jan 13, 2009 08:35 PM
lcn584
Apr 13, 2008 09:19 PM
x04CivicHatchx
Aug 25, 2007 12:47 AM
bbboltz
Apr 16, 2007 05:57 PM
95CIVICUS
Nov 29, 2005 08:39 PM
