97 civic radiator fan
Old Nov 18, 2013 | 11:04 AM
kcorwin's Avatar
Default 97 civic radiator fan
One of the radiator fans on my son's 97 honda civic comes on as soon as the key is turned on. There are two fans with two radiators, the one on the drivers side comes on, the one on the passanger side stays off. He went up to northern Michigan over the weekend and had his oil changed at Williams Quick Lube in Traverse City. The invoice showed they put 4.5 quarts in his 3.5 quart capacity engine. I checked it and sure enough had to drain a quart out, don't think this caused it but it did not do this before they did the oil change so I don't know if a wire got disconnected or what to look for.
Old Nov 18, 2013 | 11:32 AM
kcorwin's Avatar
O.K, when I get home I will first check to see if he has the defrost selected, I did not think of that obvious one.
Old Nov 18, 2013 | 03:46 PM
The fan on the left (driver's) side is only for the A/C. It doesn't have anything to do with cooling the engine. It will be on if A/C or defrost is selected.
Old Nov 19, 2013 | 02:30 AM
kcorwin's Avatar
yes, I checked it last night and works just like is was designed...brain fart on my part. Thanks for the reply.
cialert
Dec 31, 2011 07:26 AM
anivast999
May 14, 2011 06:15 PM
SilverCivicDX97
Jul 12, 2010 11:44 AM
d12bn
Nov 7, 2008 09:26 AM
hondarob
Oct 24, 2007 12:35 PM
