98 civic lx dies when driving
Old Feb 15, 2025 | 09:44 PM
nickolsvw's Avatar
Default 98 civic lx dies when driving
I have a 98 civic lx 1.6 manual transmission. Couple of months ago I started having fuel issues. I replaced the fuel filter, fuel pump, fuel relay, drained the tank and cleaned it put premium gas back in.( I never run anything but premium). Once I replaced all that I wasn't getting spark. So I replaced my map sensor, throttle positing sensor cap and rotor and the bottom o2 sensor. During all that the only code that was thrown was the 0420 code. That's why I changed the 02 sensor. Month n half later( 2 weeks ago) it died on me again. This time couldn't get it to start at all. Towed it home battery died so I couldn't check for a code. Tested my coil. It was bad. Replaced that, the cap and rotor again, and the spark plugs. Ran fine for a week. Today it died on me 3 times going to work witch is only 4 miles away. And once on the way home. Had to wait mayb 2-3 min before it would start again. Once I got it started it ran fine the rest of the way home. Only code is the 0420 code still. Was thinking it could be my camshaft sensor or crank shaft sensor. Or would a clogged cat be the issue?
I should also mention that my car was stolen a couple of times bout a year ago. They messed up my ignition. Witch I havent bothered to replace. When ever I go some were I pull the fuse for the fuel pump that way the car wont start if someone attempts to steal it again
nickolsvw
Mar 5, 2025 07:32 PM
92utownxj
Jun 30, 2015 07:10 AM
HeskettD
Dec 30, 2014 09:29 AM
_TaintedRarity_
Jan 2, 2013 05:19 PM
Infinitrium
May 30, 2011 08:46 PM
