98 civic rear bearing
Old Jul 7, 2010 | 08:07 AM
firecatf7333's Avatar
Default 98 civic rear bearing
how do I replace rear wheel bearings in a 98 civic. do I need a press?
Old Jul 7, 2010 | 09:17 AM
The complete hub with bearings is replaced as a unit. No need to press out bearings since they aren't sold separately anyway.
Old Jul 7, 2010 | 09:29 AM
Old Jul 7, 2010 | 09:33 AM
Default k
OK. do you know the size of the nut that holds bearing hub assembly together? I don't have a big enough socket, biggest I have is like 18mm. could I just use an adjustable wrench?
Old Jul 7, 2010 | 09:43 AM
Some auto parts stores offer free rentals for specialized tools, such as large socket sets that include the needed 32-mm socket.
In some cases, a gear puller helps to remove the hub bearing unit.
Old Jul 7, 2010 | 10:25 AM
Note the torque spec on that nut -- 134 ft-lb. You will need a good socket and some leverage to R&R it.
Old Jul 7, 2010 | 05:44 PM
SilverSedan's Avatar
Just a heads-up
I did mine just over a year ago, when I removed the spindle nut, the whole hub/bearing assembly fell off - EXCEPT for the inner race, which was stuck to the axle/spindle. I had to use a cutting wheel to remove it. It is not a difficult job, aside from that.
Old Jul 23, 2010 | 11:17 AM
do you have to lineup the nut with the indented stud( where you have to punch the nut down) I'm assuming you do but when I line the nut up with the correct spot where I could punch it back down, the torque isn't 134. can I go over 134 ft ponds of torque? I read 134 on my torque wrench but I'd have to make almost another complete turn to allign the nut again. is it supposed to be hard to tighten the nut are just barely snug. thanks
Old Jul 24, 2010 | 03:06 AM
You're supposed to use a new nut every time it is taken off.
Old Jul 25, 2010 | 03:53 AM
the bearing I bought didn't come with a new nut. I used old nut and used a chizzle to make a new indent in a different spot on nut.
wibblequikit
Jun 16, 2009 10:53 PM
Big red
Jul 6, 2008 09:56 PM
rdblkb18
Apr 19, 2007 01:16 PM
quickcivicexbj
Dec 1, 2006 12:17 PM
TITIKO
Jan 10, 2005 10:23 PM
