Fuse #35 blows when I plug in the condenser fan
Old 07-02-2014, 04:01 PM
Kalikooa's Avatar
Default Fuse #35 blows when I plug in the condenser fan
Hi everyone, first time formally asking a question here, but I've gotten a lot help from reading others posts here, so thank you all for that.
I have a 95 civic dx and the AC hasn't worked for the 3 months that I've owned it. I've searched thoroughly in the forums here and in the service manual, which has led me to figure out this much: fuse #35 blows when I turn the AC on, however if I disconnect the condenser fan and turn the AC on the fuse does not blow. I measured about 12V at the connector to the fan, and on the fan side a resistance that changed from anywhere between about 2 to 16 Ohms. The fan appears to be aftermarket, and has a grill that prevents me from being able to try manually spinning the fan to see if it's stuck.
Does the fact that the fuse only blows when the fan is connected mean that the fan is the problem?
Thank you for any advice you can give me.
Old 07-02-2014, 08:24 PM
The compressor and fan are on the same fuse. You could unplug the compressor and test with just the fan. If the fuse still blows, yes the fan is bad. Or try spinning it by hand. The stock fan is removed by taking the two bolts out of the top, loosen the wires and hoses (do not disconnect refrigerant hoses though, just take them off of the brackets), then slide the fan straight up.
Old 07-02-2014, 10:42 PM
Kalikooa's Avatar
Ok great, thank you. I'll try it tomorrow with the compressor disconnected.
jpcalhoun
08-03-2013 08:37 AM
TexusMain
06-14-2012 04:40 PM
jaysilver96civic
04-29-2011 05:52 AM
trustdestruction
03-31-2009 06:42 AM
lecorybusier
09-08-2007 03:51 PM
Quick Reply: Fuse #35 blows when I plug in the condenser fan
