99 CEL question
I have a 99 civic ex and i did the jumper wire method to check the check engine light codes, am i supposed to be getting a 3 digit code since my car is obd2?
RE: 99 CEL question
I got 9 flashes in a row so im guessing i have a code 9
RE: 99 CEL question
CEL codes start with the letter P followed by four numbers, the first of which is typically 0 or 1. I am not sure that the method you are using will actually reveal the code -- it may simply indicate that a code is stored in the ECM. Perhaps someone else in this forum will tell you the answer. You can definitely learn the CEL code by taking your car to AutoZone, where they will use a scan tool to retrieve the code free of charge.
RE: 99 CEL question
Bring it to Autozone and have them scan it. It's a free service they offer and if you get someone with half a brain in their head, they'll even give you tips on how to fix it.
RE: 99 CEL question
You can in fact retrieve a CEL code(s) by the jumper wire method.
The following links shows that CEL code 9 obtained by this method indicates a problem with the CYP (cylinder position) sensor or circuit. http://www.c-speedracing.com/faq/05.php http://www.c-speedracing.com/faq/06.php I discovered this information on this forum https://www.hondacivicforum.com/m_41699/tm.htm |
