99 CEL question
Old Oct 23, 2007 | 02:23 PM
Blackitalian's Avatar
Default 99 CEL question
I have a 99 civic ex and i did the jumper wire method to check the check engine light codes, am i supposed to be getting a 3 digit code since my car is obd2?
Old Oct 23, 2007 | 02:28 PM
Default RE: 99 CEL question
I got 9 flashes in a row so im guessing i have a code 9
Old Oct 23, 2007 | 03:21 PM
CEL codes start with the letter P followed by four numbers, the first of which is typically 0 or 1. I am not sure that the method you are using will actually reveal the code -- it may simply indicate that a code is stored in the ECM. Perhaps someone else in this forum will tell you the answer. You can definitely learn the CEL code by taking your car to AutoZone, where they will use a scan tool to retrieve the code free of charge.
Old Oct 24, 2007 | 03:27 AM
Bring it to Autozone and have them scan it. It's a free service they offer and if you get someone with half a brain in their head, they'll even give you tips on how to fix it.
Old Oct 24, 2007 | 06:46 PM
You can in fact retrieve a CEL code(s) by the jumper wire method.
The following links shows that CEL code 9 obtained by this method indicates a problem with the CYP (cylinder position) sensor or circuit.
http://www.c-speedracing.com/faq/05.php
http://www.c-speedracing.com/faq/06.php
I discovered this information on this forum https://www.hondacivicforum.com/m_41699/tm.htm
Badfish82
Aug 24, 2013 05:34 PM
G-Hog
12
Dec 18, 2010 06:57 PM
WellFedHobo
Nov 20, 2010 05:20 PM
FlipHKD720
Mar 14, 2007 11:08 AM
215civic
Apr 20, 2005 10:27 PM
