99 civic acting up
Old Nov 3, 2007 | 07:05 AM
tetra's Avatar
Default 99 civic acting up
my 99 civic engine just died while I was going 65 on the freeway. Had to cruise over the shoulder and restart the engine. It That was couple weeks ago. Last night the engine died again while I was backing out of my driveway but it restarted right away. What else can I do? Should I change out the gas filter and clean the fuel injection system? The car has 100k miles on it and I haven't done those things yet. Spark plugs and air filter had been changed already.
TIA
Old Nov 3, 2007 | 07:19 AM
Default RE: 99 civic acting up
During these episodes, did the Check Engine Light turned on either temporarily or constantly?
Old Nov 5, 2007 | 05:28 AM
tetra's Avatar
nope...
Old Nov 5, 2007 | 06:50 AM
wes94si's Avatar
Does it only do it after it is warmed up, I have seen clogged fuel filters do that, ALOT of bad gas was sold when Katrina hit NewOrlands everyone should have put a new fuel filter on their car after that. If that don't work you need to find out if it loosing fire, next time it does it don,t restart quickly pull one off the plugs and see if is wet or smells like gas
Old Nov 5, 2007 | 08:12 AM
tetra's Avatar
ORIGINAL: wes94si
ok. that kinda seems like the symtom of a gas filter because both times that happened, I was low on gas..not that low. Still had at 3 gallons left. But I will give that a try and hopefull it will solved the problem.
Thanks!
Old Nov 7, 2007 | 09:43 AM
tetra's Avatar
any tip on how to change out the gas filter? It looks pretty simple. One line and one line out. I know you need to disable power to the gas pump but is there anything else?
TIA
Old Nov 7, 2007 | 09:51 AM
The picture should help.
Good luck!
[IMG]local://upfiles/25538/7B9D51C0CD83403A89DA989B39FB435F.jpg[/IMG]
Old Nov 7, 2007 | 10:02 AM
civic_burns_all's Avatar
ORIGINAL: RonJ
Good luck!
ahahahah dude you really crack me up. you got picture for just about every dam question ahhahaha rofl.
but yea good job, you know what your talking about.
Old Nov 7, 2007 | 10:36 AM
I figure that (sometimes) a picture is worth a thousand words!
Old Nov 7, 2007 | 11:27 AM
ORIGINAL: RonJ
and you are correct. I'm not saying anything bad.
