99 Si Civic won't start. Starter?
Old Aug 20, 2010 | 05:40 PM
mushi's Avatar
Default 99 Si Civic won't start. Starter?
hello Forum.
My 99 Si wouldn't start this afternoon. It has power but won't turn over or click at all.
Is this a dead starter? and if so how do i replace it?..and where is it's location?
I am on vacation and without my honda civic repair manual. any help would be greatly appreciated.
-Mushi
Old Aug 20, 2010 | 06:41 PM
Can you roll start it? You will need a dependable helper or two to push the car.
Turn the headlights on, then turn the key to try to start. If the lights go out, you aren't getting enough power from the battery to run the starter. That can be the battery itself, or the cables or connections.
If the lights stay on full, try jumping the starter. To do that, locate the starter, it is easiest to describe as being at the end of a large wire from battery (+). Make absolutely sure the car is not in gear and the parking brake is set. Then pull the small wire off of the starter and use a jumper wire to connect the terminal on the starter for the small wire to the big wire from the battery. The starter should turn. If it does, usually the problem is the rubber pad on the clutch pedal that presses the interlock switch. It's like the brake light switch only much harder to reach. The switch is at the very top. The other switch on the clutch pedal is for the cruise control it doesn't affect starting at all.
Old Aug 21, 2010 | 12:37 PM
mushi's Avatar
Fixed it!
The rubber pad on the interlock switch had come off.
i super glued it permenantly pushed in.
2 part my time + 1 part your time + 1.97$ = running car.
Thank you mk378.
Old Aug 21, 2010 | 03:09 PM
zerojett's Avatar
Be warned though. That is your clutch safety switch...
The only reason I know this is because of my 88. Back then, they didn't have the switch. This means you could start the car without pushing in the clutch, even if it is in gear. So be careful.
One thing that EF owners have done, when the switch fails, is they will JB weld (or super glue) a penny in place of the rubber pad. That way, it still functions, and it will last a very long time.
Old Aug 22, 2010 | 11:48 AM
mushi's Avatar
Good to know. Luckily, i live in florida so i seldom put my car in gear when it is parked, but i'll keep your advice in mind.
etteyvees
Oct 22, 2010 05:16 PM
RP Sinisterx
Aug 21, 2010 11:38 PM
jpnolan
29
Jul 14, 2009 11:51 AM
comapro
14
Oct 20, 2008 02:05 PM
Sk8_2_rel8
Oct 10, 2006 03:20 PM
