99 Si electric window probs.
Old May 26, 2008 | 01:14 PM
CrazyBelk5150's Avatar
Default 99 Si electric window probs.
My passenger window will not go up or down. I have checked all fuses and relays and none are blown. The drivers side window works and the moon roof? Is it probably the motor?
Old May 26, 2008 | 01:23 PM
Default RE: 99 Si electric window probs.
First check whether the main switch on the driver's switch assembly is turned ON.
A bad motor is one possibility. Supply battery power directly to the passenger window motor. If it doesn't run then replace motor.
Other possibilities include:
1) Bad driver or passenger switch
2) Broken wire between motor and switches
3) Loose or disconnected ground wire
Old May 26, 2008 | 08:27 PM
cyberx32's Avatar
Yeah i got a 99 si and both my motors have died
civic2001
Jan 1, 2010 06:12 AM
peterhugill
Dec 25, 2009 11:53 AM
RyanEJ2
Sep 17, 2007 10:36 AM
tacoma5050
Jul 10, 2007 11:41 AM
97Red
Feb 11, 2006 04:04 PM
