AC compressor cuts out during heat of day
Old Jul 22, 2011 | 10:08 AM
jay1317's Avatar
Default AC compressor cuts out during heat of day
Hi all:
I am new here but would like to present a problem I have been having with my 2006 civic for over one year now. During the heat of the day here in beautiful south florida the ac cuts out, the condenser fan keeps turning etc. In the morning the ac works great, going home it generally works and during the relatively cool months it works all the time. The dealers just keep changing parts. I have spent over 1500 dollars already and the problem keeps coming up. The following parts have already been changed: Relays for both compressor and condenser fan, low pressure cut out switch, service valves (first dealer said system was leaking which was causing the problem), evaportor (second guess for leak area) and finally the thermal protector on the compressor. Also after the evaporator change out the compressor clutch no longer cycles - I had 2 degree F air coming out of the vent last evening. Anyone have any ideas about the cause. Perhaps a weak clutch coil? which weakens in the heat? The compressor sounds fine and I can cycle the clutch with the buttons on the cabin control panel. I am kind of going nuts here. It is not comfortable driving in south florida in July without AC. Thanks much for your help
Old Jul 22, 2011 | 01:23 PM
Reduce the clutch gap. The coil always gets weaker when hot, if the gap is marginal it won't pull in.
Old Jul 25, 2011 | 11:59 AM
jay1317's Avatar
Thanks for the advice - sounds right
Old Jul 5, 2012 | 06:10 AM
neons1's Avatar
Thumbs up ac compresssor clutch
Originally Posted by jay1317
Hi all:
hi im also having the same problem when is hot hot weather ac clutch not turning. when the weather is not so hot everything work.so is the thermal protector is the only problem also did you change the shim for the ac clutch.
you can email me at neons1@yahoo.com thanks?
Madness
Sep 17, 2008 01:26 PM
turkeysandwich
Jan 14, 2008 02:21 PM
damich
Feb 17, 2007 10:11 AM
remedy
Sep 21, 2006 07:16 PM
Arnold
Mar 19, 2006 05:22 AM
