AC update
Old Aug 12, 2004 | 11:36 PM
foozball's Avatar
Default AC update
I checked out the fuses under the hood, and the condensor fan fuse was blown I took out one same size and replaced it turned on the ac and it blew it out again what is up?
Old Sep 29, 2006 | 07:52 PM
Lordnismo's Avatar
Default RE: AC update
Follow the wires out and see if there is a short. what year is it. there might be a short under the battery mount where it goes into the fire wall.
Old Sep 29, 2006 | 11:55 PM
fglaustin's Avatar
you need to find out if there is another circuit that the fuse also covers.
it may be something else. have to troubleshoot.
so, what other circuit(s) do that fuse provide for ??
Old Sep 30, 2006 | 02:36 AM
deserthonda's Avatar
unplut the compressor connector, install another fuse (better yet use a circuit breaker so you don't have to keep on replacing fuses till you locate the problem,, ) and see if it blows again.........
if it does not,, chk the wiring going into the thermal protector in the compressor i have seen it short out to ground a few times .. or could be the a/c coil itself
if it still blows, you got to start doing the eliminating process ,,, disconnect the plug for the condensor fan motor , chk the wiring for a short to ground ( pinched, exposed ) ,
Old Oct 4, 2006 | 02:03 PM
coronakid's Avatar
You can check the compressor to ground to see if your compressors grounded. A bad compressor will blow fuses.
315 Customs
Oct 17, 2006 08:22 PM
jwsimons
May 4, 2005 04:52 AM
redgst
Apr 3, 2005 01:09 PM
spevie
Nov 16, 2004 01:58 AM
polo708
News, Updates & Announcements
30
Oct 15, 2004 08:49 AM
