Ah F*CK
Old May 15, 2007 | 07:46 AM
suckmycivic's Avatar
Default Ah F*CK
Well guess what?
I have "catastrophic conpressor failure" on my Civic. Is this a common thing? The guy fixing it was 1150 bucks to repair the damn car.
Yes....I live in AZ and its hot as ***** already.
Old May 15, 2007 | 07:49 AM
drbyers's Avatar
Default RE: Ah F*CK
AC compressor?
sounds like that dood is trying to take you for a ride.
go to the junkyard or search online in forums for a used compressor and install it yourself with a mechanically inclined friend or relative.
Old May 15, 2007 | 07:52 AM
the_turtle's Avatar
Default RE: Ah F*CK
fo sho.....a compressor should not be 1500 with or without labor.... im pretty sure the A/C compressor isnt even that hard to swap....if im thinking correctly its right on the front and out of the way for the most part....
agreed with byers..... Byers...i swear you need a tv show!
Old May 15, 2007 | 07:54 AM
Default RE: Ah F*CK
He wants to replace the compressor, condensor, drier and expansion valve. Ive got some calls in to my parts guy that provides me a 90 warranty. Im just waiting on that. Its hotter than s*it tho.
Old May 15, 2007 | 07:58 AM
drbyers's Avatar
Default RE: Ah F*CK
call around local junkyards or go online and search. depending on how old your car is, you can possibly get all the stuff used for a few hundred bucks and install it yourself.
there are certain online junkyard sites that will search a nationwide database for used parts for almost every make and model of car.
Old May 15, 2007 | 08:22 AM
Chopsta's Avatar
Default RE: Ah F*CK
http://www.car-part.com/
They have everything...
Old May 15, 2007 | 08:26 AM
Default RE: Ah F*CK
I already have a parts guy on it.
Old May 15, 2007 | 08:58 AM
drbyers's Avatar
Default RE: Ah F*CK
ORIGINAL: suckmycivic
I just thought about this statement ^^^.
he "wants" and "what needs" to be replaced are two different things.
i doubt very seriously, that every one of those parts failed. it may be worth your time to get a second opinion.
I'm betting the compressor or condensor broke, but not both.
Old May 15, 2007 | 09:34 AM
SilverSedan's Avatar
Default RE: Ah F*CK
Just remember that your AC is filled with compressed refrigerant...not the greatest stuff to inhale, or to have spray out under pressure into your skin or face. So if you ARE going to swap the parts, keep that in mind - along with the fact that you'll have to go to a shop to get the system recharged anyway.
Old May 15, 2007 | 09:35 AM
ryank327's Avatar
Default RE: Ah F*CK
Hes rippin you a new one. Ill be tearing out mywhole A/c system tommorow and selling it...check the classifieds in a day or two.
