Air Condition trouble 1995 DX 1.5
Old Jun 9, 2004 | 09:38 PM
derekhell's Avatar
Default Air Condition trouble 1995 DX 1.5
I searched the forum and did not find any air con info so here goes...
1995 1.5 DX Air Con compressor engages only when engine cold. When hot or on a hot day will not engage. Tried new relays already with no success. Compressor runs if power is jumped to the compressor, so I do not think it is the clutch or compressor.
Blows cold air fine when compressor running, problem is compressor sometimes will not engage.
I heard it might be the ECM / ECU! Should I try a new one?
HondaCar shop in Houston is trying to sell me a new compressor and wants to charge $1300 or more for the job! WTF!
Any help is greatly appreciated.
Derek in Houston
Old Jun 9, 2004 | 10:17 PM
NTX's Avatar
NTX
Default RE: Air Condition trouble 1995 DX 1.5
Is the system fully charged?
Old Jun 10, 2004 | 01:25 AM
polo708's Avatar
not sure the problem, but probably not the ECU.
Old Jun 10, 2004 | 10:19 AM
derekhell's Avatar
Hello,
Thanks for the replies. 6 months ago I had the system evacuated and recharged and a dye penetrant chemical added. No leak was detected with the dye and also as I said it works fine if I can only get the compressor to engage reliably.
Cheers
Derek
Old Jun 10, 2004 | 01:37 PM
NTX's Avatar
NTX
If the system is not fully charged, the compressor wont engage as often as it should, but if you've had it done a few months ago it could be a compressor problem. I would'nt pay $1300 tho.
Old Jun 28, 2004 | 07:49 PM
givey's Avatar
Did you find out what was wrong? I have a 1992 DX and I am haveing the same problem. Any help would be appreciated.
Thanks
Greg
Old Aug 3, 2004 | 05:47 PM
derekhell's Avatar
Well $1100 later, I have solved the problem. The condensor was leaking, so I had it replaced. The mechanic found the compressor clutch and coil were worn beyond specs and replaced them.
This did NOT solve the problem.
The problem was in the control panel inside the car. Replaced the control panel $250 and now it works all the time. Hope this helps somebody.
I did notice that the little internal light by the fan switch would flicker at night. If yours does this, it is likely the same problem. It was a short in the aircon button all the time.
Cheers,
Derek
Living cool in Houston this summer.
Dragon_F
Jun 5, 2009 02:10 AM
russhelp
Jun 29, 2007 12:07 PM
MCCivic
Apr 4, 2007 12:45 PM
MYoung
Sep 16, 2006 09:22 AM
DjHuey
Jun 17, 2004 04:20 AM
