air conditioning sqeaks
Old Jun 3, 2007 | 01:28 PM
DXhatch's Avatar
Default air conditioning sqeaks
My air conditioning wasnt blowing cold air so i decided to recharge it. I have a 92 civic so i used r12 refridgarent. When i was finished the ac started squeaking very loud as soon as i turn it on. It blows cold air fine. It never used to do that when the ac wasnt charged. What is the problem? Also when at idle with ac on, it squeaks for a little and then stops and keeps on repeating. please help.
Old Jun 9, 2007 | 07:22 PM
a_l_e_x1's Avatar
Default RE: air conditioning sqeaks
First, are you sure it's the AC and not something else belt-driven (like power steering)?
Second, when your AC didn't have any gas in it, you weren't using it, right? Maybe the pulley got rusty and that makes the noise. Also, the belt might be slipping, so a tightening should be done. Get that belt-anti-squeak spray at car shop and spray it where the belt touches the pulley. If the sound goes away, then the pulley is loose and you gotta tighten it.
Old Jun 10, 2007 | 07:04 AM
Tighten the belt some. If it is tight and still squeaks, put on a new belt. While you have the belt off, spin the compressor pulley and the idler by hand and see if the bearings are getting noisy. I've never had any success with the belt dressing spray.
It may be overcharged now. That puts a real strain on the compressor, thus also on the belt.
apoplectic1
Apr 18, 2010 02:07 PM
dagwood
12
Jun 2, 2005 12:15 PM
mikey203
Aug 15, 2004 09:26 PM
KazeSupra
Aug 3, 2004 06:00 PM
Seadoo1960
May 27, 2004 12:30 PM
