annoying gas pedal
Old Dec 1, 2007 | 06:08 PM
Mj96civic's Avatar
Default annoying gas pedal
I am getting very annoyed with my gas pedal. when i let off the clutch and press on the gas slowly, the gas pedal sticks for a second and the car doesnt recieve enough gas. then when i press a little bit harder the car revs up pretty high. can a get someones opinion on what may be causing the problem?
Old Dec 1, 2007 | 06:13 PM
nociv1's Avatar
Default RE: annoying gas pedal
This actually happened on my dads truck turned out his throttle body was just dirty making the throttle plate stick closed try gettting some throttle body cleaner and a toothbrush and clean it up some. It might help a little bit. Other than that the cable could be getting stuck on something.
Old Dec 1, 2007 | 08:07 PM
civicraider's Avatar
Check ur cable tension. if its loose it will stick mine did the same thing
Old Dec 2, 2007 | 05:16 AM
Mj96civic's Avatar
thanks guys
sbg20307
Jan 10, 2007 10:48 PM
conceptualpolymer
Dec 16, 2006 07:06 PM
plasticboob
May 19, 2006 02:01 AM
Goldfinger7476
Apr 24, 2005 12:16 AM
sickcivic420
13
Feb 24, 2005 08:44 PM
