Any1 got a step by step to changing combination switch?
my low beam wasnt working and i tested it and i think its the combination switch.. i was wondering if any1 got a step by step guide... I dont wanna go blindly and end up burning the rest of the wires lol
you can just replace the broken switch instead of the whole assembly. this will make the repair easier since you won't have to remove the steering wheel. at least that was the case on the 5th and 6th gen civics I've worked on.
I got a 94 eg hatch... hmm I think I did something wrong.. now my low beam doesnt work at all but when I go on to high beam than pull the switch in it goes to low beam lol.... when i changed it I put everything exactly the same. Any one know the problem before i take the whole thing apart and read through a stack of manuals lol
Combination Switch Fix (Headlight Switch)
https://www.hondacivicforum.com/foru...ad.php?t=74275
To remove it:
1. Remove the steering column cover (2-3 screws?)
2. Turn the steering wheel until you can see the 2 screws holding the combination switch in place. Remove them.
3. Pull out the switch and unplug. Then follow my DIY (link above^^) to clean switch.
If your switch doesn't work after following my DIY go to my for sale thread (link below vv)
https://www.hondacivicforum.com/foru...ad.php?t=61520
To remove it:
https://www.hondacivicforum.com/forum...ad.php?t=74275
To remove it:
To remove it:
Shandles
15
Jun 6, 2013 06:45 PM
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
peige414
Jan 8, 2008 04:07 PM
Bananaboat11
Nov 29, 2007 04:19 PM
