anything I can do about this
Old Jul 26, 2007 | 05:37 AM
ic892003's Avatar
Default anything I can do about this
My clutch pedal is real squeaky when I push it down, anything I can do?
Old Jul 26, 2007 | 06:00 AM
AgentofDarkness's Avatar
Default RE: anything I can do about this
Grease it with some white grease
Old Jul 26, 2007 | 06:16 AM
ic892003's Avatar
The pedal it self from the inside of the car??? Could I use wd40 instead
Old Jul 26, 2007 | 10:17 AM
The pedal is most likely on a hinge, so it can pivot and what not. You can use WD-40 but it doesn't stick around since its so thin. If you use white grease, which is thicker, it will stick in the hinge much longer.
Old Jul 26, 2007 | 07:51 PM
cyberx32's Avatar
Actually it might be your clutch. Is your pedal kinda hard to press? i have the same problem and i took it to the mechanic, and he said the clutch is going out.
Old Jul 26, 2007 | 09:09 PM
Always start with the simple stuff first. A can of white grease costs like $5.00.
Old Jul 27, 2007 | 12:36 AM
Masonn's Avatar
+1 to WD40!!!
Old Jul 27, 2007 | 10:45 AM
cyberx32's Avatar
yeah i guess. I only mentioned it cause i used wd40 and the squeek is still there.
SoCaL.rider
Jun 24, 2005 03:45 PM
315 Customs
Jun 20, 2005 11:16 AM
HONDA PUSHA
21
Mar 1, 2005 06:26 PM
dalifts
Sep 13, 2004 03:33 PM
