autometer gauges?
Old Jul 24, 2011 | 01:16 PM
Jonathan_89_DX's Avatar
Smile autometer gauges?
how do i install my temp and oil pressure gauge on my D15B2 motor? i tried installing them in the stock temp hole but the hold was to small and i couldnt find the oil pressure fitting either... can someone please take pics ofwereto install these gauges? i also need to know whick colour off the destributor is my tach wire
Old Jul 27, 2011 | 11:22 PM
i just need to know which holes in the engine the fitting from my autometer stuff can replace ive looked but everything seems to have wire on them and i dont wanna be messing with wiring unless i know its right..
Old Jul 29, 2011 | 09:26 PM
conceptualpolymer's Avatar
Have you thought of using an oil filter adapter plate? You thread the gauge sensors in this plate and then run the wires to the gauges and to power. Here's what my Mazda's looks like:
Untitled 1
I used Glowshift gauges and a pillar pod for a Civic (since none is available for my Mazda).
Old Jul 31, 2011 | 10:37 PM
thanks do you know where i can put the Temp ?? thats the last one i need
Old Aug 1, 2011 | 11:30 AM
You can install both oil temp and oil pressure into the adapter plate. Glowshift sells all that stuff. Also, check my pillar pod install procedure:
Honda Corner
It indicates what the tach wire looks like and where it is located in a 97 CX.
Old Aug 1, 2011 | 11:51 AM
Glowshift, Mishimoto, and many other companies offer these adaptor plates. I had a Mishimoto one on my D16, and I plan on using it for my H22 once that is ready to go.
The sensors thread directly into that.
Old Aug 5, 2011 | 05:03 PM
I need a water temp
Old Aug 5, 2011 | 06:29 PM
Doesn't your car have a coolant temp gauge?
Old Aug 6, 2011 | 07:20 PM
Ya but its not numbered out its just a bar with c and h
illycut
Apr 3, 2008 10:09 PM
03civex
Jan 27, 2008 07:59 AM
anothercivic
Jun 26, 2007 06:55 PM
Mr Mobsta Man
May 3, 2007 02:41 PM
98 S10 ON NX
Oct 19, 2006 10:00 PM
