axle doesn't look right...
I put some new axles in today, and something about the passenger side doesnt look right, it almost looks like it's too short? Can someone tell me what I may have done wrong?? This was my first time doing this. The driver side one came out fine, heres what the other side looked like....(sorry for the blurry pics, took them from my cell phone)
The nut is torqued to 134 ft-lbs in this pic....
Yes the joint has been pulled apart, it is probably the wrong axle and too short. Hold the old axle next to it and see if the length is the same.
When a joint has been pulled apart like that I think the inner rollers can fall off so you may not be able to just push it back together.
Well, I don't know if the camera's flash is to blame, but I don't see the metal ring/clamp the holds axle boot to the axle. If that is not there, it might just be that the boot is loose to move where ever, which is bad. Otherwise, yeah, she popped out.
I agree with all that the axle joint pulled apart. The same happened to me during installation of an axle on my 97 Civic, even though the axle was the correct one. I believed that the axle was defective, so I simply returned it to AutoZone. With little hesitation, they gave me a replacement axle free of charge. It worked fine.
If the joint has been pulled apart I'm assuming that it won't turn.....right? well if that's the case, then the joint isn't pulled apart because the whole axle turns with no problem.
The metal clamp that holds the boot to the axle is there, you just cant see it in the pic.
Based on the distorted axle boot, I would assume that the underlying joint will not function properly, despite it retaining some capacity to rotate. It would be most prudent to return the axle in the picture and obtain a new one.
Lordy, your verbosity is rather developed.
Translation:
Replace it.
ORIGINAL: RonJ
Replace it.
