axle popped out of trans, going to happen again?
Old Mar 7, 2012 | 08:14 AM
Mcgarvie's Avatar
Default axle popped out of trans, going to happen again?
so on day 2 on the 92 si hatch, i pulled the loose axle from the transmission to find the tip of the knuckle shaft was rounded off an the c-clip was all mangley-janked. re-installed a new knuckle thing to find it doesnt look like it goes in all the way, but i just came back from driving it around, seems to be fine.. until the next red light or what?? its got the tinyest gap between where the axle seal sit's in the face of the knuckle an the seal in the tranny.
Old Mar 7, 2012 | 09:54 AM
droopy128's Avatar
it does have a tiny gap, as long it don't leak and and when making few full turns both way and doesn't pop out.. you installed it correctly.. Yay..!!
Old Mar 7, 2012 | 01:06 PM
Don't start new threads about the same problem. If you can't pull it out by hand it's probably OK.
Mcgarvie
Mar 8, 2012 06:20 PM
Erika
Feb 18, 2011 04:32 AM
blu90hatchb16
Mar 21, 2010 04:35 PM
Method
Jan 2, 2007 08:56 PM
dre
Aug 3, 2006 02:01 PM
