Axle seal
Old Jan 8, 2011 | 05:29 PM
supradupra's Avatar
Default Axle seal
Having trouble with my passenger side axle seal. I've gone thru 3 of them, 2 aftermarket and one OEM. It seems they work for a week or so and then start leaking again. There is no visible damage to them. Could it be that my "rebuilt" axle is machined too much where it meets the seal allowing fluid to leak by. It's a 93 civic w/ a manual tranny. Thanks!
Old Jan 9, 2011 | 09:22 AM
Could very well be that. Maybe you could tell by trying the seal on the axle before installing.
Other things to look out for on axle seals:
* They are different left versus right. Look for an arrow showing the direction the shaft must normally rotate (when the car is rolling forward).
* Seal needs to be pushed into the bore flat and parallel, by pressing evenly only on it's outside edge. Pressure on the center area will bend it and ruin it.
* Always put oil (or ATF, if it's an automatic) on the lips of the seal before installing the axle. Be careful not to damage the seal by hitting it with the splined part of the axle.
jmack
Mar 15, 2011 04:27 PM
Scott53092
Jul 7, 2010 08:30 PM
RonJ
Jun 15, 2010 01:39 PM
texasmade
Jan 7, 2008 07:33 PM
em2~B!tch
Nov 30, 2007 05:02 PM
