b16 charging problem?!?
hey whats up everyone? newb here just swapped b16a in EF SI.
battery light is on and car cuts off after 5 min driving. iv gone through 3 alternaters, all were for a 90 gsr (thats what i was told to get), and 2 batterys. still car is only charging at 12.6v same as battery V. the original alt was jdm do i need a jdm alt or are all b series the same. my car/ecu is obd0 running stock SI harness. thanks in advance any help appreciated
You need to have power at the "I" wire of the alternator with the key on. Also the ECU can reduce alternator output on command by one of the other wires, but I forget exactly how that works. Basically if your harness is miswired the alternator will not work properly.
GMstorm
Apr 20, 2010 02:46 PM
rcvicdude
Nov 1, 2009 12:55 PM
SirTealingstonThe2ND
Jan 3, 2008 12:58 PM
