b18a1 idle problem
Old Aug 4, 2006 | 01:03 AM
smokingemcee's Avatar
Default b18a1 idle problem
I have a b18a1 that does not idle correctly. The rpms rise and drop from approx 1200 - 2500 rpms at a times.
The engine runs smooth though when in gear.
I'm throwing no codes.
I have taken the valve on the back of the intake manifold ( coolant runs through it) off and let it sit in seafoam for approx 15 minutes. I did not completley take it apart, only the piece that's held onby 3 screws. The other bolt looking thing I don't have the proper wrench for.
Do I need to take that off too? Should I try a different cleaning method?
Should it sit in some cleaning soloution longer then 15 mins?
Old Aug 4, 2006 | 02:01 AM
finalimpact's Avatar
Default RE: b18a1 idle problem
remove the fitv below the throttle body.........remove the 2 screws where the coolant line goes in.........tighten dow the white cap and reinstall. usually this is the problem.
Old Aug 4, 2006 | 11:16 AM
fglaustin's Avatar
what is "fitv" ?
smoking: could you give the year; do not know what year b18a1 is in ??
Old Aug 4, 2006 | 11:58 AM
fglaustin's Avatar
OK i found the engine. 90 to 93 integra.
i think that will troubleshoot the same as 88 to 91 honda that i posted about over on another thread. you can use this thread to troubleshoot if you have not already got it fixed:
https://www.hondacivicforum.com/m_248797/tm.htm
92sicivic
Jun 21, 2012 03:35 PM
redlines4us
Aug 22, 2006 05:49 AM
HondaSuperman
May 22, 2005 01:07 AM
ohbiskits
ED-EF Swaps
Apr 5, 2005 03:37 PM
