B18C Head Gasket Question
Old Aug 22, 2009 | 11:32 AM
EJ8_Man's Avatar
Default B18C Head Gasket Question
Hi,
Does anyone know the stock thickness on a B18C ITR head gasket. 98+ Spec ITR.
And can anyone give me a general idea on how much it will cost to have the block & head machined before re-installing the head gasket?
Old Aug 22, 2009 | 01:58 PM
you just need the head milled the block should be fine and it usually cost less than 100 bucks
and any b18 head gasket will do
Old Aug 22, 2009 | 11:25 PM
EJ8_Man's Avatar
Hmm. I was concerned about compression. I see gasket kits that are pretty cheap, and then I also see gaskets that come in different thicknesses. So I was thinking if I can get the stock thickness, and then add on however much metal is lost through the milling process I can preserve my compression. I am weary about using the cheaper gaskets. I would really like to plan on taking the head off once in this motor's life So I am going to go with a more expensive performance head gasket.
slade8
Dec 6, 2009 06:23 PM
legal
Jan 26, 2008 09:35 PM
95lsvtec
Feb 14, 2006 11:46 PM
civicpimpinsc
Feb 1, 2006 10:36 AM
civicpimpinsc
Jan 7, 2006 07:58 PM
