bad ground wire/s??
Old Jul 28, 2010 | 07:02 AM
gtb1977's Avatar
Default bad ground wire/s??
i need to change my ground wires in the engine just wondering how many there are. i know of 2 but just asking if anybody knows more. thnx 4 the help
Old Jul 28, 2010 | 07:20 AM
Most models just have two stock. One from battery (-) to the frame and then to the transmission. The other from the valve cover to the radiator support. You can always add more if you want to. Why do you think you need to change them?
Old Jul 28, 2010 | 07:28 AM
gtb1977's Avatar
guy at advanced did a drain test and came back 0.13. dont really know what that means but he said it shld read 1.?? plus the cars got 200k and they're original. im slowly replacing everything.
Old Jul 28, 2010 | 07:30 AM
I don't know what that "drain test" means either. Realize that the guys at Advance typically don't know a lot about cars. You should check that the connections on the ground wires are clean and tight.
xsdudztx
Aug 14, 2007 05:45 PM
khanselman
Aug 18, 2006 02:02 PM
:94CIV:DX:
Jul 21, 2006 09:33 AM
Ohiocivic
May 24, 2006 10:35 PM
skytanker2003
Jan 9, 2006 11:45 AM
