Black Smoke at VTEC?
Old Jun 17, 2008 | 09:26 PM
JW93EX's Avatar
Default Black Smoke at VTEC?
In my 98 EX I have a stock 2000 B16A. When I punch the gas at get high rpm's and when theVtec kicks in it will blow black greyish smoke. I am assuming it is running rich. Also the inside of the rear tail pipe is black.
I do have a check engine light on due to the secondary 02 sensor not functioning due to the wires before it getting fried for some reason.Can the secondary 02 sensor not functioning cause theengine to run rich? or may it just need a tune-up or injector cleaner?
Old Jun 17, 2008 | 09:49 PM
PREKGSR's Avatar
Default RE: Black Smoke at VTEC?
ur running rich , i have the same issue u just need to get it tuned
Old Jun 17, 2008 | 10:30 PM
derekautomatica's Avatar
tune the air fuel ratio and you're set
Old Jun 17, 2008 | 10:31 PM
JW93EX's Avatar
Thanks guys! How do I go about tuningthe air fuel ratio. The engine and fuel pressure reg is stock.
Old Jun 18, 2008 | 01:12 PM
check your valves too. does it have mechanical or hydraulic lifters?
Old Jun 18, 2008 | 03:41 PM
JW93EX's Avatar
I have no idea. Its a 2000 B16A w/ 40,000 original miles. I am pretty sure it is just running rich.
Old Jun 18, 2008 | 11:07 PM
civicraider's Avatar
if you change the rear o2 sensor that can have an impact on y ur running rich.
Old Jun 19, 2008 | 06:46 AM
JW93EX's Avatar
That did cross my mind, although I thoughtall the secondary o2 sensor does is measure the catalyst.
HondaEGcoupe
Jun 27, 2009 06:11 PM
bakertime
Feb 3, 2008 07:03 AM
anonymous4l
12
Aug 7, 2007 10:01 AM
4doorcivic9
Apr 8, 2007 12:06 AM
crazyching
Jul 25, 2006 11:19 PM
