Black soot out tailpipe? Too much oil to turbo?
Old Dec 30, 2005 | 10:04 PM
rx9790's Avatar
Default Black soot out tailpipe? Too much oil to turbo?
Guy i bought my civic from gave me a valve and said to install inline with turbo oil feed to reduce oil flow because it was getting too much and blowing out the exhaust. result is a blackened rear bumper and trunk lid i have to wash constantly. Can this be the case? I wouldnt think you could get too much oil flow. 99 dx d16y7 engine running 6lbs boost. It does puff mild black smoke when i shift moderately hard i was told.
Old Dec 30, 2005 | 10:19 PM
AgentofDarkness's Avatar
Default RE: Black soot out tailpipe? Too much oil to turbo?
I think black soot is solid carbon i believe. I looked it up in my big book about cars and it says that the soot is known as particulates. It is caused by fuel additives. Maybe that helps, it probably doesn't.
Old Dec 30, 2005 | 10:42 PM
sacicons's Avatar
yeah, blck smoke is unburnt fuel. oil smoke would be bluish.
Old Dec 30, 2005 | 10:44 PM
Pete's Avatar
What are you using for fuel management?
Old Dec 30, 2005 | 10:51 PM
If your car is running as rich as it must be running for all that black smoke and soot, then there should be a check engine light and a corresponding code. I think autozone/pep boys will tell you the code for free.
Old Dec 31, 2005 | 07:29 PM
rx9790's Avatar
Running a Hondata chip piggyed on an OBD1 cpu. No cel but cant pull codes either.
Old Dec 31, 2005 | 07:33 PM
rx9790's Avatar
ORIGINAL: sacicons
How can i lean out the mix? I beleive the smoke isblack but I havent seen it myself. I know the soot on the rear end is blackish.
Old Dec 31, 2005 | 08:20 PM
joey's Avatar
if yer car's burning rich it could be your oxygen sensor. but i think you'd have a check engine light.
Old Dec 31, 2005 | 09:16 PM
sacicons's Avatar
its hard to lean it out safely with a Hondata, without a new chip. get it on the dyno and get a new chip burnt.
Old Jan 1, 2006 | 11:14 PM
rx9790's Avatar
ORIGINAL: joey
With an OBD1 cpu in an OBD2 car?
