Blower fan selector not working properly
Old Nov 29, 2007 | 08:52 AM
91SIHB's Avatar
Default Blower fan selector not working properly
If I turn the fan speed selector to 1 or 2, the blower motor does not kick in but3 and 4 work just fine. I have already swapped the switch from one at the wreckers and it also does the same thing. Either the one I got also has the same problem, or it is not the switch. Any ideas?
91 Civic SI HB
Old Nov 29, 2007 | 02:15 PM
OLD n TIRED's Avatar
Default RE: Blower fan selector not working properly
Might check out blower motor RESISTOR. Track wire from blower motor up to where it connects to resistor. Remove resistor (usually two screws) pull out of housing and have tested
Old Nov 29, 2007 | 08:36 PM
Yes it's usually the resistor. Remove the glove box and you'll see the resistor mounted in the top of the air duct leaving the fan. Unplug it; it should have a four wire plug. There should be only a few ohms resistance between any two terminals. If one or more terminals are open, it is bad.
rpfn140378
Jan 31, 2012 02:24 PM
civicex2001
Sep 25, 2010 02:11 PM
radix99
Aug 4, 2010 10:56 PM
TheOnlyBFC
May 1, 2010 07:30 AM
carlosian
Jan 12, 2007 08:19 PM
